I wish that little voice would have shouted in my ear the first time I took mine apart.Ditto Mega thanks for your info on rebuilding the forks (gasman, et al) and the pinch bolts on the front wheel axle. I had just put a long screwdriver and a rubber mallet on the work bench to pound that cotton-pick in' axle out when the idea fairy lighted on my shoulder and whispered in my good ear to check the Forum out first. SOOO glad I did..so is my BD K9!
Use Stainless not Chrome on those pinch bolts there so it will only be a grade 5. Just so if it happens again it's a LOT easier to drill out.I wish the little voice had told me the bolt was already bottomed out before that last twist.... Bushing and left hand drill and I will get it removed. Shorter bolts will go back in.....
Yeah, the axle would not tighten up so I just kept cranking. I hope it drills out easy....ha!Use Stainless not Chrome on those pinch bolts there so it will only be a grade 5. Just so if it happens again it's a LOT easier to drill out.
I actually think the manual states Stainless too...and only like 12 ft/lbs or something.
