SKOGDOG
One of the old ones.
Needing to replace the (in tank) fuel filter in an EFI 2010 Bagger. The pickup of fuel is accomplished by pulling gas first through a filter, then (@about 60-65 psi) into a hose leading to the fuel pump. I would assume that the fuel pump does not intake fuel at 60 psi...but that's just an assumption.
In removing the filter for replacement, I noticed that the hose has a very sturdy pinch-type clamp on the pinch clamp (I don't know if that is the right name for this thing). I literally had to hacksaw the damn thing off, and as is true of many things I destroy, I find no way don't have a way to replace it, something all we Dog owners are familiar with. The clamp has a band underneath it, and they had to have used a special a tool to pull up that the clamp. It is barely visible in the upper center of the picture of the old filter below. Apologies for the poor shot, but you've all seen those before.
Here is the question: Do I need to use another pinch clamp like the one in the photo when I install the new filter, or can I use a standard worm-gear type clamp? And if it needs a pinch clamp, where can I get that done or acquire the tool?
Hoping someone with solid experience with fuelies can provide counsel here. I suspect the fuel pickup is not as pressurized as the outflow of fuel to the injectors, but would like to know how serious that clamp has to be..........
Kudos as always to the geniuses of Dognostics
