Bubba_BigDog
Redneck
Anyone ever hear or use aircraft oil that's intended for air-cooled engines instead of standard oil generally intended for water-cooled engines?
Yep, same here, Mobil 1 is da chit!Mobil 1, 20-50w is intended for V-twins, not vehicles
Not on my Dog cause it is not needed, but on my boat, yes. I have dug out the mil spec and found marine oils that are identical to aircraft oils. Needless to say I do not pay too much for aircraft oils since I work in the industry, but West Marine and others charge you an arm and a leg for certain fluids. If you have access to get them and the mil specks are compatible, why not?Anyone ever hear or use aircraft oil that's intended for air-cooled engines instead of standard oil generally intended for water-cooled engines?
Yes! Whatever he said....haDon't do it unless you want your S&S to die a quick death. I've been a licensed A&P mechanic for over 30 years. Aircraft reciprocating engines are for the most part air cooled, the oil used in them are vastly different than a motorcycle. They use a mineral based oil for break-in and then go to an AD oil (Ashless Dispersant). Aviation oils lack the friction modifiers required by motorcycle engines. They also never see the heat created by a typical air cooled motorcycle engine. Aircraft engine can also control their CHT and or EGT somewhat by having a manual mixture control and through the use of engine cowl flaps. But hey, if you want to try it, it's a free country. Just my 2 cents.
I couldn't have said it better, well doneDon't do it unless you want your S&S to die a quick death. I've been a licensed A&P mechanic for over 30 years. Aircraft reciprocating engines are for the most part air cooled, the oil used in them are vastly different than a motorcycle. They use a mineral based oil for break-in and then go to an AD oil (Ashless Dispersant). Aviation oils lack the friction modifiers required by motorcycle engines. They also never see the heat created by a typical air cooled motorcycle engine. Aircraft engine can also control their CHT and or EGT somewhat by having a manual mixture control and through the use of engine cowl flaps. But hey, if you want to try it, it's a free country. Just my 2 cents.
CHT ( cylinder head temp) EGT (exhaust gas temp), im a licensed A&P too, CheersDawggydawgI got the 2 cents worth but still stuck on the "CHT and or EGT"
After a few beers I bet you could haveI couldn't have said it better, well done
Fur surAfter a few beers I bet you could have
Yup that's the stuff, use Royal Purple in everything...Stay with my Royal Purple 20/50
