These are the only recalls that I remember. Made sure they were completed on my 2008 Mastiff:
Make: BIGDOG Model: K9, MASTIFF, RIDGEBACK
Model Year: 2008
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: SEP 11, 2007
NHTSA CAMPAIGN ID Number: 07V460000
N/A
NHTSA Action Number: N/A
Component: FUEL SYSTEM, GASOLINE
ELIVERY:HOSES, LINES/PIPING, AND FITTINGS
Summary:
ON CERTAIN MOTORCYCLES, THE FUEL LINE CAN POTENTIALLY CONTACT HEATED METAL PARTS OF THE MOTORCYCLE AND MELT.
Consequence:
THIS CONDITION COULD OCCUR WITHOUT ANY PRIOR WARNING AND COULD RESULT IN FUEL LEAKAGE. FUEL LEAKAGE, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE.
Remedy:
DEALERS REPLACED THE FUEL LINE WITH ONE THAT HAS HIGHER THERMAL RESISTANCE PROPERTIES. ALSO NEW FUEL LINES WERE REROUTED TO FURTHER REDUCE EXPOSURE TO HEATED METAL. ALL MOTORCYCLES HAVE BEEN REPAIRED. NO OWNER NOTIFICATION WILL BE NECESSARY.
Make: BIGDOG Model: K9, MASTIFF, MUTT
Model Year: 2008
Manufacturer: BIG DOG MOTORCYCLES, LLC Mfr's Report Date: DEC 11, 2007
NHTSA CAMPAIGN ID Number: 07V580000 NHTSA Action Number: N/A
Component: STRUCTURE:BODY
Summary:
ON CERTAIN MOTORCYCLES, THE REAR FENDER STRUT ATTACHING BOLTS CAN FAIL ALLOWING THE REAR FENDER TO DETACH FROM THE MOTORCYCLE.
Consequence:
THIS COULD OCCUR WITHOUT PRIOR WARNING AND COULD RESULT IN AN INJURY OR A CRASH.
Remedy:
DEALERS WILL REMOVE EXISTING STRUT BOLTS AND REPLACE WITH HIGHER TENSILE STRENGTH ATTACHING BOLTS AND UPDATED WASHERS. HIGHER TORQUE VALUES WILL BE OBSERVED WHEN INSTALLING THE REPLACEMENT FASTENERS. THE RECALL BEGAN ON JANUARY 21, 2008. OWNERS MAY CONTACT BIG DOG AT 316-267-9121.
