"Official" battery cranking amp requirement from Big Dog ?
Knuckles
You need one of these kits.... they are awesome! :old2:
Charges Phones/Tablets with 2A USB Output
  • 200CCA Constant - 400CCA Max
  • Cables & Adapters Included: 12V Mini Jumper Clamps, Universal USB Cable w/3 Cellular Tips
And its pocket size.
Bought one of these over Labor Day rally when my battery capped out. Jump started it right up! Guy said they've used it to start a diesel truck!
bearman
I have had mine about two years. I have jumped my chevy suburban with it, it took 4 trys to get a good connection. much easier the second time with 2 people. each start would use 25% of its capacity (but when it would loose connection it didn't use any). However it would not help start my car that has the battery in the trunk, but each try would still use 25% of the microstart.
I just recently used it on the mastiff for the first time, spins it like you have a new battery and the spark plugs are out.
Big Willy
I bought mine from Curtis / Wild Steed Works. His price was not the lowest; however I appreciate his support of this forum, and Big Dog owners in general. And the service was excellent. You won't be disappointed.
LARS
sippin & cruzin
Why don't you just try with an other battery? Like the one you have in your car, if using jumper cables do not run the car engine! Maybe the battery is bad...
Tapio
I had a bad experience with that,car not running,bike battery started smoking and put a hole in the side of bike battery,,,I'll never do that again
Reddickracing
Here's one to check out a few of us are using it, Harley batteries are great I never had a problem with them but this one is noticeably more powerful
MX20L - MOTORCYCLE BATTERY - 500+ CCA https://www.amazon.com/dp/B01E49MQZ4/ref=cm_sw_r_cp_apip_YzkdpF4C62deB
Hey Dentdude I need a battery and Iv seen you post info on this one a few times. Could you tell any dif when you hit the starter button and does it still have that same thump. Would you buy it again? Its American made too I see. You got one so I guess just want your opinion on it.
Thanks
