francoblay1
The Spaniard
Old subject I guess but just for curiosity....
:up:You need the"i don't need any option"Franco.i do use the syn3 in the harleys with no issues
20w50 is good for Motor & Primary but for the Trans you need the Amsoil Severe Gear 75-110. :up:Amsoil 20w50 in everything but the gas tank.
ATF is made for wet clutches and chains. My clutch slipped all the time.:2thumbs:ATF type F.
yes sir...same here. 2004 Ridgey, Could never get the clutch adjusted right, thought it was the clutch pack. Took it all apart, measured each and every plate. Followed a bloggers advice, reassembled and filled it with ATF..... haven't had an issue since:2thumbs:ATF is made for wet clutches and chains. My clutch slipped all the time.
Put ATF in. Never slipped again
In everything no... only motor & primary... for trans 70-140. (or something like that from memory) but also from Amsoil.Amsoil 20w50 in everything but the gas tank.
