Franco, if you can't see the gas because it's dark, use a lighter!:roll:Have you tried GGLE?
Fuel Gauge at Motorcycle Superstore
NOTE: Honestly the fuel gauges are not accurate or worth it IMO. Most people stick to mileage as it is more accurate and reliable. Even on bikes that I have had with a gas gauge, 1/4 tank could mean I was empty or was at a half tank. I never trusted it. I don't even really use mileage anymore. I look in my tank, if I can't see gas, its time to fill up.
:lol::lol::lol::lol::lol:Franco, if you can't see the gas because it's dark, use a lighter!:roll:
:loony::roll::roll::roll::loony::roll::roll::roll: you wanker! :roll::roll::roll::roll: :2thumbs:Franco, if you can't see the gas because it's dark, use a lighter!:roll:
:roll: This method is recommended also for removing moisture from inside the tank.:lol:Franco, if you can't see the gas because it's dark, use a lighter!:roll:
Its also recommended you do this outdoors:zwhistle:Really???? I must try!!!!
Never thought about it :bang:
Thank you so much.... your input is very much appreciated!!! :2thumbs:
:roll:
did you ever find fuel quantity indicator solution for carb bikes?I haven't run out of gas but I'd still like to have an indicator better than just the idiot light on my K-9.
Since I am fuel injected I am going to build my own fuel gauge based off a design already done on the internet at ecomodders -- basically it reads the amount of time the injector is on and does the math -- this is usuallly very accurate once setup since it measures fuel that has come out of the tank not where some silly float is.
I might get energetic and replace the entire digital dash with a unit with this feature using an Arduino (examples are already on the net) Could add almost any sensor/display you'd want
oil psi
oil temp
head temp
mpg/fuel left
gps (also theft deterrent/pager)
options are endless even without getting a huge display that would belong on a bagger!
Actually I am working on a mod for this design that will work on carb bikes as well. Probably not quite as accurate but will be pretty close -- stay tuned)
No - haven't really been working at all on that as I haven't been riding my carb bike lately. Will let you know if I do. Winter is coming and then when I work on that kind of stuff.did you ever find fuel quantity indicator solution for carb bikes?
Actually think I just found a solution that someone else has already done.No - haven't really been working at all on that as I haven't been riding my carb bike lately. Will let you know if I do. Winter is coming and then when I work on that kind of stuff.
Neat but that looks a bit big to hide on a chopper? That board looks to be about 5" x 4" alone nevermind the Bluetooth. Would need to pot it to keep water out?Actually think I just found a solution that someone else has already done.
Check this out.
http://malebuffy.blogspot.com/2014/04/bt-fuel-managergauge.html
Uses a sensor and sends the data to a smart phone. I may use this sensor when I build my unit this winter as it will be the same for EFI and carb!
Seems like a lot of trouble and components to go bad just to replace the trip meter.did you ever find fuel quantity indicator solution for carb bikes?
Sounds lazyMy new bike has a fuel gauge and a low fuel light when it gets low, and the bonus is, its all new digital technology
cruise control on it is just like a cars, I hope I don't fall asleep riding itSounds lazy
You mean the Ski Doo?My new bike has a fuel gauge and a low fuel light when it gets low, and the bonus is, its all new digital technology
Booooooooooooring.....My new bike has a fuel gauge and a low fuel light when it gets low, and the bonus is, its all new digital technology
